Setting Display and Caching preferences
You can change the display options for certain parts of the program. For example, you can change the appearance of tool cursors, reset the scaling quality of the Zoom, and set thumbnail sizes for the Effects Browser. You can also specify preferences for saving an image cache and setting a scratch disk.
Scratch disks
Setting a scratch disk (sometimes called a "swap disk") enables the application to distribute operations across your main disk and a secondary disk. This extends the memory available to the application when working on several large files at one time. Your best option is to choose a drive on a second internal hard disk (SCSI, SSD, IDE, SATA) that has more than 500 MB of free space. Avoid using the main drive where the application is installed if possible. Removable drives are not supported and the configuration of the drive determines if it is available as a scratch disk.
Important! If you set your main drive as a scratch disk, ensure that you have more than 2 GB of free disk space. On some systems, using the main drive for a scratch disk causes performance issues. Unmark the scratch disk check box if this occurs.
Display settings in Windows
The Display settings in Windows affect Corel PaintShop Pro and other applications on your computer system. Corel PaintShop Pro is optimized for the 100% display option in Windows. If you see text cut off or elements of the user interface cut off (truncated), please check your Display settings in Windows (Control Panel Appearance and Personalization Display).
To set Display and Caching preferences Back to Top
Edit workspace
Manage workspace
In the Presentation group box, mark the Re-use last type in file save-as dialog check box.
In the Presentation group box, unmark the Display all color dropper tooltips check box.
In the Presentation group box, mark the Use precise cursors check box.
In the Presentation group box, mark the Show brush outlines check box.
Adjust the Zoom / Rescaling Quality slider.
In the Caching group box, mark the Merged Image check box.
In the Caching group box, mark the Merged Below Active Layer check box.
In the Caching group box, mark the Merged Group check box.
In the Scratch disk group box, mark the Enable scratch disk check box and choose a disk from the drop-list.
