Setting Undo preferences
The Undo settings control some behavior of the Undo and Redo commands, as well as one option for the History palette.
To set Undo and Redo preferences Back to Top
Edit workspace
Manage workspace
Mark the Limit undo/redo disk usage to check box, and type or set a value in the control.
Mark the Limit undo/redo to check box, and type or set a value in the control.
Mark the Enable fast redo check box. This may slightly slow down the undo process, so if you rarely perform a redo, but use undo frequently, you may want to unmark this check box.
Type or set a value in the Non-undoable steps in History Palette control.
