Straightening images
You can easily straighten crooked images by aligning a straightening bar with an image feature. Corel PaintShop Pro rotates the image so that this straightening bar is perfectly horizontal and vertical. This feature is especially useful when an image has a strong vertical or horizontal feature, such as a building or horizon.
The Straighten tool lets you position a straightening bar within an image.
To straighten an image Back to Top
Edit workspace
Before clicking the Straighten tool, click the layer name on the Layers palette.
Mark the Rotate all layers check box on the Tools Options palette.
Type or set a value in the Angle control on the Tools Options palette.
Mark the Crop image check box on the Tools Options palette.
Unmark the Crop image check box on the Tools Options palette.
You can also double-click the image to apply the command.
