Viewing images
You can view images in a tabbed format, in which a tab appears at the top of the image window. When you click a tab, the image in that window becomes the active image. You can also view images in windows, which you can move, resize, or close. You can open the same image in multiple tabs or image windows, which lets you see the image at different magnification levels.
The Tabbed Documents mode (left) lets you maximize your image viewing space. To view several images at the same time (right), turn Tabbed Documents mode off.
If you have multiple images open, you can arrange the image windows to view them side by side or stacked in cascading order. You can also see a list of all open images.
If the image is larger than the image window, you can pan to view different parts of the image, or you can fit the window to the image. You can also see a thumbnail of the entire image in the Overview palette. For more information, see Using palettes.
The title bar at the top of the image window shows the filename and the magnification percentage. An asterisk after the filename indicates that the image has been modified and that those changes have not been saved.
If the image has an embedded watermark, a copyright symbol is displayed in front of its name. For more information, see Using digital watermarks.
To enable or disable the tabbed image window option Back to Top
Edit workspace
To view another image, click its tab. If an image tab is not in the current view, click the arrows in the upper-right corner of the image window to scroll left or right.
To close a tabbed-format image, click the Close button .
To move an image window Back to Top
Edit workspace
To resize an image window Back to Top
Edit workspace
When you resize an image window, you are not changing the size of the image.
To minimize or maximize an image window Back to Top
Edit workspace
Click the Minimize button .
Click the Maximize button .
Click the Restore Up button .
To close an image window Back to Top
Edit workspace
You can also click the Close button on the title bar.
To close all windows, choose Window Close All.
To make a copy of the active image Back to Top
Edit workspace
You can also duplicate the active image by pressing Shift + D.
To open multiple views of the same image Back to Top
Edit workspace
To arrange multiple windows Back to Top
Edit workspace
Choose Window Cascade.
Choose Window Tile Vertically.
Choose Window Tile Horizontally.
To see a list of all open images Back to Top
Edit workspace
To view another area of the image Back to Top
Edit workspace
On the Tools toolbar, choose the Pan tool , and then drag in the image. If any other tool is active, hold down the Spacebar, and then drag in the image.
Press F9 to display the Overview palette, click the Preview tab, place the pointer inside the panning rectangle, and drag. You can also set the zoom level in the Preview tab of the Overview palette.
To fit the image in the image window Back to Top
Edit workspace
Choose Window Fit to Image.
Choose Window Fit to Window.
Choose Window Fit to Screen.
