| To mix colors |
| 1 | On the Materials palette, set the Foreground and Stroke Property box to Color, and choose a color from the Frame, Rainbow, or Swatch tab. |
| Note: When any Art Media tool is active, the mode buttons below the Foreground and Stroke Property and Background and Fill Property boxes are inactive. |
| 2 | On the Mixer palette, select the Mixer Tube tool |
| 3 | In the Mixer area, drag to apply paint strokes. |
| If you want to change the width of the stroke, change the setting in the Size box. |
| Note: You can choose another color by repeating step 1. |
| 4 | Choose the Mixer Knife tool |
| To undo and redo color mixing |
| • | On the Mixer palette, click one of the following buttons: |
| • | Unmix |
| • | Remix |
You cannot undo or redo Mixer Tube and Mixer Knife tool actions by choosing Edit
Undo or Edit
Redo, by clicking the Undo and Redo buttons on the Standard toolbar, or by pressing Ctrl + Z or Ctrl + Alt + Z.
| To use Mixer palette colors |
| 1 | On the Mixer palette, choose the Mixer Dropper tool |
| Note: Dragging around the Mixer area on the Materials palette updates the Foreground and Stroke property box with the current sampling position. |
| 2 | On the Tools toolbar, choose an Art Media tool. |
| 3 | Begin painting. |
| Note: The strokes will be applied on an Art Media layer. If this layer type is not the active layer, one is created automatically once you begin using the Art Media tool. |
| 4 | To choose another color, use the Mixer Dropper tool to choose the desired color from the Mixer area. |
Hold down the Navigate button
On the Mixer palette, choose Clean Page.
The size of the Dropper tool is determined by the Size setting on the Tool Options palette.
You can dry the Art Media layer, or make it wet again by choosing Layers
Dry Art Media layer or Layers
Wet Art Media layer. For more information on each Art Media tool, see Working with Art Media tools.
| To create a custom Mixer page |
| 1 | Choose File |
| 2 | In the Image Dimensions group box, type values to set the dimensions for the Mixer page. |
| Note: The width and height must be at least 500 pixels. |
| 3 | In the Image Characteristics group box, click the Art Media Background option. |
| 4 | Click the texture swatch in the Select canvas texture area, and choose a texture from the menu. |
| Note: The texture acts like an invisible surface on which Art Media pigments are applied. |
| 5 | Click OK. |
| Note: At this point you can apply Art Media pigment to the image. |
| 6 | On the Standard toolbar, click the Save button |
| 7 | Navigate to X: Program Files(x86)\Corel\Corel PaintShop Pro X7\Corel_17 for 32-bit or X: Program Files\Corel\Corel PaintShop Pro X7 (64-bit)\Corel_17 for 64-bit, where "X" indicates the drive on which Corel PaintShop Pro is installed. |
| 8 | Save the new image in the .pspimage file format. |
On the Mixer palette, choose Save Page or Save Page As, and type a name for the page.
You can fill the Mixer page with a color by marking the Enable fill color check box in the New Image dialog box, clicking the Color box, and choosing a fill color. Be aware, however, that you cannot sample this color, nor will the Art Media tools affect the color.
| To load Mixer area pages |
| 1 | Click the Load Mixer Page button |
| 2 | Click the Mixer page you want, or navigate to the folder where the Mixer page is stored. |
| Note: By default, Mixer pages are saved in ...Documents\Corel PaintShop Pro\17.0\Mixer Pages. |
You can also load a mixer page by clicking the Mixer Menu icon
and choosing Load Page.
