Zooming and panning
By default, images that you open in Corel PaintShop Pro appear at a magnification level that allows the full image to appear in the workspace. You can zoom in to get a closer look at image detail or zoom out to view a larger portion of the image. You can also magnify a specific area of an image.
You can view image areas that fall outside the current image window. For example, when you are working at a high magnification level, you can pan or jump to a different image area without having to adjust the magnification level. When an image is too large to fit within its window, scroll bars appear on the bottom and right sides of the image.
You can use the Zoom tool to magnify your image (left) or you can use the Magnifier command to view a specific area without changing the magnification of the image (right).
To zoom Back to Top
Edit workspace
Choose View Zoom to 100%, or click the Zoom to 100% button on the Tool Options palette.
By default, when you zoom in or out, the image window automatically resizes to fit the image.
You can also change the magnification when the Zoom tool is active by using the scroll-wheel if one is included on your mouse or stylus.
You can also change the magnification of an image by choosing View Zoom in and View Zoom out.
To magnify an image area Back to Top
Edit workspace
To turn off the magnifier mode, choose View Magnifier again.
To pan around an image Back to Top
Edit workspace
Hold down the Spacebar, and drag with the other tool.
To fit the window to the image Back to Top
Edit workspace
You can also fit the window to the image by clicking the Fit Window to Image button on the Tool Options palette when the Pan tool or Zoom tool is active.
