Adding drop shadows to layers
You can add a drop shadow to a single layer or to a group to enhance the appearance of an image. Drop shadows are also helpful for developing Image Hose nozzles.
When you add a drop shadow, Corel Painter creates a new layer for the shadow and groups it with the original. This enables you to select and modify the drop shadow layer independently from the original layer.
To add a drop shadow
Back to Top
1 Select a layer or group.
2 Choose Effects Objects Create Drop Shadow.
3 In the Drop Shadow dialog box, type values in the following boxes:
• X-Offset and Y-Offset — specifies the distance, in pixels, from the center of the layer image to the shadow
• Opacity — specifies the degree to which the shadow covers underlying images. Setting Opacity to 100% obscures underlying images; lower values create a more transparent shadow.
• Radius — specifies the amount of blur at the edge of the shadow. The radius is half the distance across the blurred region. If you set Radius to zero, you create a sharp-edged shadow.
• Angle — specifies the direction of the blur.
• Thinness — specifies the amount of blur applied perpendicular to the Angle. If a blur shows streaks, increase Thinness to soften it.
If you want to merge the drop shadow layer with the image layer, enable the Collapse to one layer check box.
