Adjusting text kerning and leading
You can fine-tune the spacing between letters by adjusting the kerning. You can also adjust the amount of space between lines of text by adjusting the leading. You may want to change the leading from the default setting which is set at 100%.
To kern text
Choose the
Text tool
from the toolbox.
In the
Layers panel, select a text layer.
Click the
Show or hide the Text panel button
on the property bar, and adjust the
Tracking slider
in the
Text panel.
To adjust leading
Choose the
Text tool
from the toolbox.
In the
Click the
Leading slider
in the
Text panel.
