Applying effects to text
You can alter the appearance of text or text drop shadows by applying different effects. You can apply a composite method to text, as you would with other types of layers, to control how the text interacts with the underlying image.
You can also adjust opacity, which controls the transparency of text or shadows. Your text’s shadow should be semitransparent. You can also use opacity to fade the color of text.
In addition, you can add either a focus blur or a directional blur to text and shadows. Focus blurs make text fuzzy. You can use the focus blur to soften the edges of text characters. With directional blurs, you can specify the direction in which the blur occurs.
To apply a composite method to text
Choose the
Text tool
from the toolbox.
In the
Layers panel, select a text layer.
On the property bar, click on the following buttons:
Text Attributes
Shadow Attributes
4
Choose an option from the
Composite Method list box.
To adjust text opacity
Text Attributes
Shadow Attributes
Move the
Opacity slider
to the left to increase transparency or to the right to increase opacity.
To blur text
In the
Layers panel, select the
Text layer or the
Shadow layer.
Text Attributes
Shadow Attributes
Click the
Show or hide the Text panel button
on the property bar, and adjust the
Blur slider
in the
Text panel.
If you want to apply a directional blur, enable the
Directional Blur check box, and adjust the
Directional Blur slider
The first half of the slider adds a left-to-right blur on the text; the second half adds an up-and-down blur.
