Choosing flow maps and compatible brush variants
To quickly get started with flow maps, you can choose one of the flow map brush variants. They are available under the Real watercolor brush category. These brush variants enable flow maps by default. You can experiment and choose a different flow map to produce the effect you like.
Brushstrokes using three Real watercolor brush variants with the Fine Dots flow map selected
Brushstrokes using three Real watercolor brush variants with the Gravel flow map selected
To choose a flow map brush variant
Back to Top
1 From the Brush Selector, choose the Watercolor : Real brush category.
2 Choose one of the following brush variants:
Melted Bristle
Fringe
Small Wash
Hard
Back to Top
1 Click Window Search, type flow map in the Search text box, and choose a brush variant from the list.
2 On the Brush tool property bar, click the Flow Map flyout button .
3 Click a flow map swatch in the Flow Map Textures area.
You can also choose a flow map in the Flow Maps panel (Window Media Panels Flow Maps).
