Computed Circular controls
The Computed Circular controls allow you to specify the tip profile of brushes using the Computed Circular dab type. For example, you can customize the dab opacity and hardness, which controls the color density at the outer edge of the dab.
You can set some Computed Circular controls on the property bar. For more information, see To choose a dab profile using the property bar.
To customize a Computed Circular dab profile
Choose
Window
Brush Control Panels
Brush Shape
Computed Circular.
Perform a task from the following table.
Move the Dab Opacity slider to the left to reduce the opacity. Move it to the right to increase the opacity.
Control the color density at the edge of the dab
Move the Dab Hardness slider to the left to reduce the color density and create a soft dab. Move it to the right to increase the color density and create a hard dab.
