Constraining, fading, and undoing strokes
Using the freehand stroke drawing style, you can constrain your strokes to a straight line. The angle you draw depends on the orientation of the stroke.
You can also make a stroke less opaque, or more translucent, by fading the stroke.
In this example, a brushstroke was applied to the canvas (left) and then fade was applied to the brushstroke (right) by using the Fade dialog box (center).
In addition, you can undo a stroke. You can also control how many individual strokes can be undone, see Performance preferences.
To constrain freehand strokes
Back to Top
Hold down Shift as you drag.
To fade a stroke
Back to Top
1 Choose Edit Fade.
2 Drag the Undo Amount slider.
To undo a stroke
Back to Top
Choose Edit Undo Brush Stroke.
You can also undo a stroke by pressing Command + Z (macOS) or Ctrl + Z (Windows).
