Converting dynamic layers
At some point, you may want to finalize the dynamic plug-in effect and convert the result to a default layer. This allows you to work with the image in ways not possible when the effect is held in a dynamic layer.
Converting a dynamic layer captures its current appearance to a pixel-based layer. After a dynamic layer is converted, you can no longer adjust the effect. The following operations automatically generate a prompt to convert a dynamic layer:
• painting on a dynamic layer
• applying an additional effect or dynamic plug-in
• dropping a dynamic layer
• collapsing a group that contains a dynamic layer
• saving to a non-RIFF format
To convert a dynamic layer to a default layer
Back to Top
1 In the Layers panel, choose a dynamic layer.
2 Click the Layer options button , and choose Convert To Default Layer.
