Using the Kaleidoscope Painting mode
Corel Painter lets you to transform basic brushstrokes into a colorful and symmetrical kaleidoscope image. When you paint a brushstroke in one kaleidoscope segment, multiple reflections of the brushstroke appear in the other segments. You can apply between 3 to 12 mirror planes to a kaleidoscope. You can also rotate or reposition the mirror planes to expose different colors and patterns. You can restore the default settings of the Kaleidoscope tool at any time.
The green lines that are displayed in the document window delineate the symmetrical planes.
To create a kaleidoscope painting
In the toolbox, click the
Kaleidoscope tool
In the
Segments box on the property bar, type the number of planes that you want to display.
Click the Brush Selector on the Brush Selector bar.
4
Click a brush category, and click a brush variant.
5
Apply brushstrokes in any of the kaleidoscope segments.
If you want to achieve a spiralling effect, apply brushstrokes across multiple segments.
Hide the kaleidoscope planes while painting
Click the Mirror Planes toggle button  on the Kaleidoscope tool  property bar.
Disable the Kaleidoscope Painting mode
Disable the Kaleidoscope check box on the Kaleidoscope tool  property bar.
Turn off the Kaleidoscope Painting mode
Click the Stroke Options flyout button  , and click Mirror Painting  .
The Brush tool is the only tool that you can use to create mirror and kaleidoscope paintings. Other tools, such as the Shape tool, are not supported.
To control the display of the kaleidoscope planes
Kaleidoscope tool
Perform a task from the following table:
Specify an angle of rotation
On the property bar, type a value in the Rotation Angle box.
Rotate the plane in the drawing window
Point to a plane until the cursor changes to a rotation angle cursor  , and then drag to rotate the plane.
Change the plane position
Point to the center point of the planes until the cursor changes into a four-headed arrow  , and then drag it to a new location in the drawing window.
Change the color of the plane
Click the Symmetry Plane Color button, and choose a color from the color picker.
To restore the default settings of the Kaleidoscope Painting tool
Click the
Reset Kaleidoscope button
on the property bar.
