Customizing flow maps
You can create a custom flow map by using an existing paper texture or by capturing an area of an image.
To customize an existing flow map, you can rotate it. You can also modify the scale, contrast, and several other settings of a flow map the same way that you would modify paper texture. For more information, see Working with paper texture and grain. Note that flow maps benefit from increased scale and contrast; therefore, if you create a flow map from a paper texture or image, you should increase the scale and contrast.
An area of an image was selected (1) to create a flow map (2).
To create a flow map from a paper texture
In the
Papers panel (
Window
Media Panels
Papers), click a paper texture swatch.
In the
Flow Maps panel (
Window
Media Panels
Flow Maps), click the
Create From Current Paper button
If you want to rename the flow map, right-click (Windows) or Control-click (macOS) the swatch, and choose
Rename Flow Map.
To capture a flow map from an image
Open or create an image.
Choose the
Rectangular Selection tool
from the toolbox.
Drag in the document window to select the area of the image.
4
In the
Flow Maps panel (
Window
Media Panels
Capture Flow Map button
If you want to blend the distinction between tile borders, drag the
Crossfade slider to the right in the
Capture Flow Map dialog box.
5
Type a name in the
Save As text box.
The flow map is added to the currently selected library.
To customize a flow map
In the
Flow Maps panel (
Window
Media Panels
Flow Maps), click a flow map swatch in the
Flow Map Textures area.
Perform one or more actions from the following table.
Invert the flow map effect
Click the Invert button  .
Resize the flow map pattern
Control the contrast of the flow map
Move the Contrast slider. A higher setting alternates the flow map pattern from high to low more quickly and with fewer intermediate levels than a lower setting.
Control the brightness of the flow map
Move the Brightness slider.
When the Brush tool
is active, you can customize the currently selected flow map by clicking the Flow Map flyout button
on the property bar and adjusting the settings you want.
