Editing, renaming, and deleting scripts
Corel Painter lets you modify scripts in different ways. You can edit script instructions in order to change a recorded action sequence. You can also rename and delete scripts.
You can edit a script by opening it as a series of instructions that contain parameters, most of which are editable. You can also edit a script by exporting the script (.txt file) and then opening the file in a text editor. For more information, see Importing and exporting scripts.
To edit script parameters
Choose
Window
Scripts.
In the
Scripts panel, click the script that you want to edit from the Scripts library viewer.
Click the Scripts options button
, and choose
Edit Script.
Corel Painter displays a list of the script’s instructions in the
Edit Script dialog box.
4
Double-click the instruction line that you want to edit.
5
Double-click a parameter within the instruction.
6
In the parameter’s dialog box, make the necessary changes.
8
In the
Edit Script dialog box, click
Done to save the changes to the script.
The open script becomes the current script and is displayed in the Scripts library viewer. If you choose another script from the Scripts library viewer, the open script does not change.
You can also edit a script by exporting the script and then opening the script file in a text editor. You can export a script by clicking the Scripts options button
in the Scripts panel, and then choosing Export Script.
To rename a script
Choose
Window
Scripts.
In the
Scripts panel, choose a script from the Scripts library viewer.
Click the Script options button
, and choose
Script Library View
Rename Script.
4
Type a new name in the
Save As box.
To delete a script
Choose
Window
Scripts.
In the
Click the
Delete button
