Editing color sets
You can customize color sets by adding, deleting, or replacing colors. You can also append colors to a color set. This is useful if you want to use colors from multiple color sets. In addition, you can name or rename individual colors in a color set.
Naming colors in a color set can be useful. You can then search for a color by name, or annotate the colors you use, right in the document window. For more information, see To find a color in a color set.
To add a color to a color set
Back to Top
1 In the Color panel, choose a color.
2 In the Color Set Libraries panel, choose the color set where you want to add the selected color.
3 Click the Add Color to Color Set button.
You can also
Add a sampled color to a color set
Click the Dropper tool in the toolbox, click a color in the image, then click the Add Color to Color Set button .
Add a color from another color set
Drag a color swatch from one color set to another.
To delete a color
Back to Top
1 In the Color Set Libraries panel, choose a color and click the Delete Color from Color Set button .
2 In the warning dialog box, click Yes.
Corel Painter deletes the chosen color from the color set.
To replace a color
Back to Top
1 Choose the color you want to add from the Color panel, a color set, or an existing image.
2 Hold down Command (macOS) or Ctrl (Windows), and click the color you want to replace.
The new color replaces the old one in the color set.
To show or hide a color
Back to Top
• Perform a task from the following table.
To
Do the following
Hide a color
Right-click a color swatch in the Color Set Libraries panel, and choose Hide Color.
Show all hidden colors
In the Color Set Libraries panel, click the Color Set options button , choose Color Set Library View, and choose Show All Hidden Items.
To name or rename a color
Back to Top
1 Right-click a color swatch in the Color Set Libraries panel, and choose Rename Color.
2 Type a color name in the New name box.
Color names can contain up to 31 characters.
To restore the default color set
Back to Top
• In the Color Set Libraries panel, click the Color Set options button , choose Restore a Default Color Set.
