Saving, exporting, and importing custom palettes
You can save a custom palette as a Painter Custom Toolbox (BOX) file so that its custom content such as custom brushes, papers, patterns, and flow maps are saved with the file. You can share the saved custom toolbox (palette) with others or store it for later use.
You can also export a custom palette to the Painter Palette File (PAL) format to make it compatible with earlier versions of Corel Painter. However, any custom content included in the palette is not saved with the file.
To save a custom palette as a Painter Custom Toolbox (BOX) file
Choose
Window
Custom Palette
Organizer.
Choose a palette from the
Custom Palette list.
4
In the
New Palette File dialog box, type a name in the
File Name text box.
5
Choose the drive and folder where you want to save the file.
It’s a good idea to store all saved palettes in the same folder.
Custom nozzles, scripts, gradients, looks, and weaves are not supported. Buttons for such custom content will not function when the custom toolbox is imported.
Any non-custom items that are already in the application appear as duplicates.
To export a custom palette to the Painter Palette File (PAL) format
Choose
Window
Custom Palette
Organizer.
4
In the
File Name text box.
5
It’s a good idea to store all exported palettes in the same folder.
Custom content is not saved with the file.
To import a custom palette
Choose
Window
Custom Palette
Organizer.
In the
Custom Palette Organizer, choose a palette from the
4
In the
Open Palette File dialog box, choose the file where the custom palette is saved.
Only custom palette files created with Corel Painter version 8.1 or later are supported. Custom palettes created with version 7 or earlier cannot be loaded.
