Rearranging panels and palettes
Whether you are new to digital painting software or a long-time user, Corel Painter makes it easy to adapt your design space to your needs. The interactive panels in Corel Painter are single tabbed containers that let you access content libraries, commands, controls, and settings. Panels are stored in palettes.
A typical palette features a header bar (1), a Palette Drawer button that lets you turn a palette into a palette drawer (2), panel tabs (3), and a Panel options button that allows you to access a series of related commands (4).
You can increase your efficiency by arranging task-related or frequently used panels into palettes. For example, you can display all color-specific panels in one color palette, or display panels individually. A palette can contain one or more panels.
This palette includes three color-related panels: Color, Mixer, and Color Set Libraries. You can access a panel’s content by clicking its tabs.
Corel Painter includes the Brush controls palette, which is a preset palette that groups all panels that contain brush-related settings.
You can add panels to and remove panels from a palette. You can also reposition a panel within a palette group or move a panel to another palette group. You can turn a palette into a palette drawer, so you can quickly collapse it to save screen space. At any time, you can turn a palette drawer back into a regular palette. You can resize and reposition a palette drawer like any other palette group.
You can display and hide a panel or palette. When you hide a panel or palette, they are no longer displayed in the application window. If you want to keep the panel or palette at hand, but save screen space, you can resize or collapse them.
You can also arrange panels and palettes in the application window to quickly access the tools and controls that you use most often or to maximize screen space. Palettes and panels float in the workspace. Docking attaches the panel or palette to the vertical edge of the application window. Undocking detaches them from other parts of the workspace, so you can move them. To perform docking, you need to grab a panel’s tab or a palette’s header bar.
You can save the arrangement of palettes as a custom workspace layout for later use, and you can delete this custom workspace layout when you no longer need it.
To group panels into palettes
Back to Top
• Perform a task from the following table.
To
Do the following
Group panels into a palette
Drag a panel by its tab to another open panel to create a group.
Add a panel to a palette group
Drag the panel tab to the palette.
Remove a panel from a palette group
Drag the panel tab out of the palette.
Reposition a panel in a palette group
Drag the panel tab to a new location in the palette.
To create a palette drawer
Back to Top
• Click the Palette Drawer toggle button on the palette header bar, and click Palette Drawer.
To rename a palette drawer, click the Palette Drawer toggle button on the palette header bar, click Rename, and type a new name.
To turn a drawer into a regular palette, click the Palette Drawer toggle button on the drawer header bar, and then click Palette Drawer.
To hide or show a panel, palette, or palette drawer
Back to Top
• Perform an action from the following table.
To
Do the following
Hide a panel
Click the Close button on the panel tab.
Hide a palette or palette group
Click the Close button on the header bar.
Show a panel
Choose Window [Panel name].
Show a palette drawer
Choose Window Palette Drawers [Palette Drawer name].
When you choose Window Show Panels, only the panels that were open when you chose Hide Panels are displayed.
You can restore a previously hidden palette by choosing Window, and choosing the name of a panel that is contained in the palette.
To expand or collapse a panel or a palette drawer
Back to Top
Do the following
A panel
Double-click the panel tab.
A palette drawer
Double-click the header bar of the palette drawer.
To resize a panel or palette
Back to Top
To
Do the following
Resize a panel or palette proportionally
Point to the lower-right corner of the panel or palette. When the cursor changes to a double-sided arrow, drag the panel or palette to resize it.
Resize a panel or palette vertically
Point to the lower edge of the panel or palette. When the cursor changes to a double-sided arrow, drag the edge of the panel or palette to resize it.
Resize a panel or palette horizontally
Point to the right edge of a panel or palette header. When the cursor changes to a double-sided arrow, drag the edge of the panel or palette to resize it.
To dock or undock a palette
Back to Top
To
Do the following
Dock a palette
Drag the palette header bar to the vertical edge of the application window. The palette snaps into place when it lines up with the edge.
Undock a palette
Drag the blank area to the right of the panel tabs away from the edge of the application window.
Dock a palette drawer
Before you dock the palettes in a palette drawer, save your arrangement of palettes as a custom layout so you can return to it at any time. Choose the palette drawer that you want to dock. Click the Palette Drawer toggle button on the palette header bar, and disable Palette drawer. Grab the header bar, and drag the entire group of palettes towards the vertical edge of the application window. Ensure the cursor goes all the way to the edge of the application window. When a blue highlight appears, release the mouse button or lift the stylus. The palettes snap into place. After you dock the drawers that you want, save your layout.
Tips:
• You can undock the palettes, but only one at a time.
• You can quickly return to the arrangement of palettes that you saved in the first step by choosing Window Layout [Layout name], where Layout name is the name of your custom layout.
Dock a panel
Drag the panel tab to the vertical edge of the application window. The panel snaps into place when it lines up with the edge.
Undock a panel
Drag the panel tab away from the application window.
If there’s not enough space along the vertical edge of the application window (for example, if you have a lot of expanded palettes), you may not be able to dock a panel or a palette. Collapse one or multiple panels to create sufficient space for docking.
You cannot dock panels or palettes with toolbars.
To access additional panel options
Back to Top
• In the panel, click the Panel options button , and choose an option.
To save an arrangement of palettes as a workspace layout
Back to Top
1 Choose Window Layout Save Layout.
2 In the Palette Layout Name dialog box, type a name in the New Layout list box.
The workspace layout appears as a menu item under Window Layout.
You can display a saved arrangement of palettes by choosing Window Layout [Layout name].
You can restore the default palette arrangement at any time by choosing Window Layout Default.
To delete a workspace layout
Back to Top
1 Choose Window Layout Delete Layout.
2 In the Delete Palette Layout dialog box, choose a layout from the Palette Layout list box.
