Rotating images and the canvas
You can rotate an image on the screen to accommodate the way you draw naturally. You can also rotate the canvas to change the image orientation.
Rotate an image to accommodate the way you naturally draw. Artwork by Lennart Moberg.
Rotating an image onscreen is meant for drawing purposes only; whereas rotating the canvas modifies the appearance of the image. For example, if you print an image that you rotated onscreen, the rotation is not reflected in the printed image. However, if you rotate the canvas of the image, the rotation is reflected in the printed image.
You can rotate an image or the canvas by a predefined amount, or you can choose the amount of rotation. You can also reset the original orientation of an image.
To rotate an image
From the toolbox, click the
Rotate Page tool
If you prefer using a keyboard shortcut, hold down
Option +
Spacebar (macOS) or
Spacebar +
Alt (Windows).
The cursor changes to a hand with a pointing finger
Drag in the document window to rotate the image.
The new rotation angle appears on the property bar.
Constrain rotation to 90° increments
Hold down Shift while rotating.
Rotate an image by specifying a rotation angle
Type a rotation angle in the Rotation Angle box on the property bar or in the Navigator panel.
You can also rotate an image from the Navigator panel by typing a value in the Rotate canvas box or by opening the Rotate Canvas slider and adjusting the rotation.
To reset the original orientation of an image
In the toolbox, click the
Rotate Page tool
Do one of the following:
Click once in the document window.
Double-click the
Rotate Page tool
On the property bar, click the
Reset Tool button
You can also reset image rotation from the Navigator panel by clicking the Reset Rotation button
To rotate the canvas
Choose
Canvas
Rotate Canvas.
Perform a task from the following table.
Rotate the Canvas layer 180 degrees
Choose Canvas Rotate Canvas 180.
Rotate the Canvas layer 90 degrees clockwise
Choose Canvas Rotate Canvas 90 CW.
Rotate the Canvas layer 90 degrees counterclockwise
Choose Canvas Rotate Canvas 90 CCW.
Rotate the Canvas layer by a user-defined amount
Choose Canvas Rotate Canvas Arbitrary, and type a value in the Angle box.
If your document has layers of different types, you are prompted to commit all of them to default, pixel-based layers.
