Storing layers as images in the Image Portfolio
The Image Portfolio is a convenient place to store layers as images so you can use them again.
You can create your own Image Portfolio libraries to organize images by category. When you’re creating a library, keep in mind that the smaller the library, the easier it will be to see its contents at a glance.
You can also move items between Image Portfolio libraries. For more information, see Working with libraries.
To display the Image Portfolio panel
Back to Top
• Choose Window Media Panels Images.
If the Image Portfolio panel is not expanded, double-click the Image Portfolio panel tab.
To add a layer to the Image Portfolio
Back to Top
1 Select a layer.
2 In the toolbox, click the Layer Adjuster tool .
3 In the Image Portfolio panel, click the Image Portfolio options button , and choose Add Image To Portfolio.
The layer is added to the portfolio.
4 In the Save Image dialog box, type a name in the Save As box.
The Image Portfolio holds only pixel-based layers. If you want to add a shape, Watercolor, Liquid Ink, or dynamic layer to the Image Portfolio, you must first convert it to a default layer. In the Layers panel, right-click the layer, and choose Convert To Default Layer.
To use an image from the Image Portfolio
Back to Top
1 Choose Window Media Panels Images.
2 Double-click an item in the Image Portfolio panel to add it to the document window.
Corel Painter places the Image Portfolio item on a new layer.
