Using the Layout Grid
The Layout Grid provides an easy way to divide your canvas so that you can plan your composition. For example, you can divide your canvas into thirds vertically and horizontally to use the compositional rule of thirds. From the Layout Grid panel, you can access grid settings, such as the number of divisions, size, angle, color, and opacity of the grid. You can adjust these settings while you work and save them as a preset for future drawings and paintings. You can also move the grid to a new position. You can restore the default settings of the Layout Grid tool at any time.
The Layout Grid also lets you divide the canvas into compositional sections based on the proportions of the canvas. This nonprinting grid is used primarily for composing artwork before you begin drawing or painting.
The Layout Grid helps you compose images. Artwork by Chris Melby.
To show or hide the Layout Grid
Choose
Canvas
Compositions, and choose either
Show Layout Grid or
Hide Layout Grid.
You can also show or hide the grid by clicking the Layout Grid tool
in the toolbox and enabling the Layout Grid check box on the property bar.
To set Layout Grid options
Choose
Window
Composition Panels
Layout Grid.
In the
Layout Grid panel, ensure that the
Layout Grid check box is enabled.
Perform a task from the following table.
Set the number of vertical and horizontal divisions
In the Divisions area, type values in the Vertical box and the Horizontal box.
If you want to link the Vertical and Horizontal values, click the Synchronize Divisions button  .
In the Size area, move the Vertical slider to set the height, and move the Horizontal slider to set the width.
If you want to resize the grid proportionally, enable the Synchronize Sizes button  .
Change the angle of the grid
Type a value in the Rotate box to set the degree of the angle.
Change the color of the vertical or horizontal gridlines
In the Display area, click the Horizontal or Vertical color picker, and choose a color.
Change the opacity of the grid
Move the Opacity slider to the left to increase transparency. Move the slider to the right to increase opacity.
You can also set some Layout Grid options by clicking the Layout Grid tool
in the toolbox, and modifying the settings you want on the property bar.
To save Layout Grid settings as a preset
In the
Layout Grid panel, modify the settings you want, and click the
Add button
In the
Add Preset dialog box, type a name for your preset in the
Preset Name box.
The preset appears in the
Preset list box.
You can also save a preset by clicking the Layout Grid tool
in the toolbox and clicking the Add button
To delete a Layout Grid preset
In the
Layout Grid panel, choose the preset you want to delete from the
Preset list box.
Click the
Delete button
You can also delete a preset by clicking the Layout Grid tool
in the toolbox, selecting a preset from the Preset list box on the property bar, and clicking the Delete button
To choose a Layout Grid preset
In the
Layout Grid panel, choose a preset from the
Preset list box.
To move a Layout Grid
In the toolbox, click the
Layout Grid tool
The cursor changes to a hand icon
In the document window, drag the grid to a new position.
To restore the default settings of the Layout Grid tool
Click the
Reset button
