Working with color profile policies
Corel Painter lets you create color profile policies for opening and placing both RGB and CMYK images. The options that you choose for the Color Profile Policy determine how colors are managed in images that you open and work with in the application.
When creating a color profile policy for opening and placing images, you can specify the following:
RGB color profile to apply to images
CMYK color profile for converting images to RGB
rendering intent (depends on image content)
For more information, see What is a rendering intent?.
The color profile policy lets you display warning messages when a document has a mismatched or missing color profile. In the case of a mismatched color profile, you can choose a new color profile. If the document does not have a color profile associated with it, you can apply a new color profile or choose not to use color management with the document.
To create a color profile policy
Choose
Canvas
Color Management Settings.
Choose one of the following options from the
RGB Images list box:
Use embedded profile — applies the embedded RGB color profile to RGB images that you open or import
Use default RGB profile — converts the image by using the default RGB color profile that you specify in the color management settings
Convert CMYK Images list box:
Use default CMYK profile — converts to RGB by using the default CMYK color profile that you specify in the color management settings
Use embedded profile — converts to RGB by using the embedded CMYK color profile
4
Choose a color engine from the
Color Engine list box.
5
From the
Rendering Intent list box, choose one of the following options:
Perceptual — is recommended for a variety of images, especially bitmaps and photographs
Saturation — is best for vector graphics (lines, text, and solid-colored objects, such as charts)
Relative Colorimetric — is ideal for producing proofs on inkjet printers
Absolute Colorimetric — preserves the white point and can be used to proof images
If you want to display a warning message when you open a document that has a mismatched color profile, enable the
Profile Mismatch check box.
![*](images/note.svg)
For more complete descriptions of rendering intents, see What is a rendering intent?.
![*](images/tip.svg)
You can also access the Color Management Settings dialog box from the Navigator panel by clicking the Open Navigator Settings button
, clicking Color Management, and choosing Color Management Settings.
