You can adjust the size and shape of a selection by adding or subtracting selection areas.
If you are using the Oval Selection tool or the Rectangular Selection tool , you can select a circular or square area by holding down Shift while dragging. |
You can also add to a selection by holding down Shift and selecting the area that you want to add. If you are using the Oval Selection tool
and you want to select a circular or square area, you need to release Shift for a moment and then hold down Shift again while dragging.
When making selections, you can use any combination of selection tools, including the Magic Wand tool
. If you combine pixel- and path-based selections, the result is a pixel-based selection. For more information about creating pixel-based selections with the Magic Wand tool, see To select an area by using the Magic Wand tool.
Adding to a path-based selection
If you are using the Oval Selection tool or the Rectangular Selection tool , you can select a circular or square selection by holding down Shift while dragging. |
You can also subtract from a selection by holding down Option (macOS) or Alt (Windows) and selecting the area you want to subtract. If you are using the Oval Selection tool
and you want to select a circular or square area, you need to hold down Option + Shift (macOS) or Alt + Shift (Windows) while dragging.
Subtracting from a path-based selection
You can also load selections from the Selection Portfolio, a library of ready-to-use selections. In addition, you can use Boolean operations to combine existing selections with alpha channels.
