| • | To adjust tile dimensions |
| • | To adjust tile variability |
| 1 | Choose Effects |
| 2 | Choose the Dimensions option from Settings list box. |
| 3 | Adjust any of the following dimension sliders: |
With the Pressure slider set to zero, a light stroke produces narrow tiles, and a heavier stroke creates wider tiles.
Increasing the Pressure slider also increases the effect of pressure on the width of the tiles and prevents the creation of narrow tiles in response to a light stroke. Setting Pressure to 100% creates uniformly wide tiles, regardless of the pressure.
In this example, the Pressure slider is set to 0% (top) and 100% (bottom).
| 2 | Choose the Randomness option from Settings list box. |
| 3 | Adjust any of the following dimension controls: |
In this example, Width randomness is set to 92%.
In this example, the Length slider is set to 98%.
In this example, the Cut slider is set to 90°.
In this example, the Grout randomness is set to 100%.
