At the top of the Effects menu, Corel Painter displays the last two effects you applied. This lets you quickly reapply frequently used effects. You can also use keyboard shortcuts to apply the last two effects.
Choose Effects, then choose one of the options at the top of the menu. |
Press Command + / (macOS) or Ctrl + / (Windows). |
You can also apply a shortcut key to the 2nd Last Effect command by clicking Edit
Preferences
Customize Keys. Clicking the Effects category in the Application Commands list, clicking the 2nd Last Effect command to select it, and typing a shortcut key in the Shortcut column.
