Blending impasto with other layers
You can control how Impasto brushstrokes blend with images on other layers by selecting a Composite Depth method in the Layers panel.
The Composite Depth menu provides the following methods for combining Impasto brushstrokes:
An example of the Add composite depth method
An example of the Subtract composite depth method
An example of the Replace composite depth method
You can set a different composite depth method for every layer in a document. For more information, see Blending layers by using composite methods.
