If you regularly work with documents that contain similar dimensions, formatting, and resolution, you can create document templates so that you don’t have to start each document from scratch. When creating a template, you can add content to the canvas and save it as part of the template.
In the Save (macOS) or Save Image As (Windows) dialog box, save the file to one of the following folders in your user folder: |
In a multiuser environment, only users with Administrator status can add files to the Templates folder.
In Windows, you need to ensure that all hidden files are displayed in order to access the AppData folder.
Choose File Open Template {template name}. |
You can also open a template by choosing Help
Welcome, and then choosing a template from the Open an Image Template list box.
