Corel Painter Help :
Workspace tour : Creating, importing, exporting, and deleting workspaces
Corel Painter lets you completely customize your workspace to suit your workflow needs. You can customize Brush libraries, Paper libraries, and Portfolios and save these changes to use later. In addition, you can easily create multiple workspaces, each with different libraries and portfolios. You can even share these customized workspaces with others by importing or exporting them. However, if you are importing a workspace that was created in an older version of Corel Painter, only libraries and custom palettes are preserved in Corel Painter 2018.
You can also delete any obsolete workspaces.
Choose Window Workspace New Workspace. |
From the Based On list box, choose the workspace on which you want to base the new workspace. |
Choose Window Workspace [Workspace Name]. |
Choose Window Workspace Import Workspace. |
Choose Window Workspace Export Workspace. |
Choose Window Workspace Default. |
Corel Painter lets you modify the default workspace, so this workspace may eventually differ from the factory default workspace. If you restore the factory default workspace, you will lose all customizations unless you save the workspace. For more information, see Restoring the default Corel Painter settings.
Choose Window Workspace Delete Workspace. |
From the Workspace list box, choose the workspace that you want to delete. |
