Corel Painter Help :
Textures : Using textures in photo painting and image compositing
You can use textures in photo painting and creating composite images. For information about using textures as clone sources, see To use a texture as a clone source. After you create or modify a texture, you can embed it as a clone source. For information about working with embedded clone sources, see Working with embedded clone sources. Store your content assets as textures in a texture library and reuse them in your projects.
In the Textures panel (Window Media Control Panels Textures) or in the Texture Libraries panel (Window Media Library Panels Textures), select a texture, click the Options button , and click Embed Texture as Clone Source Image. |
![*](images/note.svg)
Transparency in PNG images is maintained.
