| • | To fade an effect |
You use the Fade control to undo a percentage of the last effect applied to the image. You can use this feature to control the intensity of an effect.
Fade was applied to the image (right) to undo a percentage of the last effect (left).
| To fade an effect |
| 1 | Choose Edit |
| To apply Fade, you must have previously applied an effect to the image. |
| 2 | In the Fade dialog box, move the slider. |
| If you change your mind, choose Edit |
