You can combine movies by inserting the frames of one movie into another. You can insert a movie before or after a specific frame, at the start of a movie, or at the end of a movie.
You can insert only Corel Painter movie (FRM) files. You cannot insert frames from QuickTime, AVI, or numbered files. However, if you open a QuickTime or AVI file in Corel Painter, you can save it to the FRM format in order to insert it into another Corel Painter movie.
In the Select Movie dialog box, locate the movie that you want to insert. |
The movie you insert must have the same frame size (width and height) as the current movie. You will also get better results if both movies use the same frame rate.
