Corel Painter Help :
Patterns : Painting with patterns
Corel Painter lets you paint patterns directly onto an image using a brush that uses the rendered dab type. When painting with a pattern, you can apply the pattern as is, or you can modify its appearance. For example, you can paint a pattern with a mask, which generates a pattern with a transparent background. You can also paint subtle patterns by adjusting the opacity, which produces a translucent effect.
Choose Window Media Control Panels Patterns. |
Choose Window Brush Control Panels General. |
If the Source list box in the General controls panel is not available (appears gray), the selected brush category does not support patterns. For example, the Pattern Pens brush category supports patterns. |
6
From the General controls panel, choose a dab type from the Dab Type list box. |
If the Source list box in the General controls panel is not available (appears gray), the dab type does not support patterns. For example, the Projected and Rendered dab types support patterns. |
7
From the Source list box in the General controls panel, choose one of the following options: |
Pattern — paints with a pattern containing no mask information |
Pattern with Mask — paints using the mask data contained in the pattern (not all patterns contain mask data) |
You can also paint with a pattern by choosing a brush variant from the Pattern Pens category.
If you have not set a clone source, Corel Painter uses the current pattern in any operation related to clone source colors or luminance. This means you can paint with a pattern by using a Cloner brush.
When painting with a pattern, keep in mind that direction matters. Corel Painter flips the pattern you’re painting when you change directions, so apply strokes in the same direction to achieve a uniform effect.
Choose Window Brush Controls General. |
6
If the Source list box in the General controls panel is not available (appears gray), the dab type does not support patterns. For example, the Rendered dab types support patterns with opacity. |
7
In the General controls panel, choose Pattern As Opacity from the Source list box. |
Pattern As Opacity is the only computed dab type that responds to methods (Cover and Buildup), allowing it to respond to Graininess. |
Corel Painter applies the current color, using luminance in the pattern to control opacity. Light colors in the pattern are rendered as transparent (or as having very low opacity). Dark colors in the pattern are rendered as very dark (or as having high opacity).
