| • | To specify performance preferences |
To ensure the optimal performance of scratch disks, consider the following:
| • | Choose a drive that does not contain the files that you are currently working on. |
| • | Choose a different drive than the one used by the operating system’s virtual memory. |
| • | Defragment the scratch disk drive on a regular basis. |
The performance preferences are described in the following table.
The number of Undo levels applies across all open documents. For example, if you set 5 undo levels and have two open documents, undoing three operations on the first document leaves you with only two undo operations on the second document.
| • | Do one of the following: |
| • | (macOS) Choose Corel Painter 2018 menu |
| • | (Windows) Choose Edit |
