| • | To perform offset sampling in a document |
| • | To perform offset sampling between documents |
It is important to note that the sampling reference point, also known as the source, is not treated as a clone source. The sampled area does not appear in the Clone Source panel.
| 1 | Click the Rubber Stamp tool in the toolbox. |
| If you want to adjust the size of the sampled area, type a value in the Size box, or adjust the slider on the property bar. |
| 2 | Hold down Option (macOS) or Alt (Windows), and click to set the source reference point. |
| A green marker appears on the image to indicate the reference point for the source image. |
| 3 | Hold down Option + Shift (macOS) or Alt + Shift (Windows), and click to set the destination reference point. |
| A red marker appears on the image to indicate the destination point. |
| 4 | Apply brushstrokes to the destination area to reveal the sampled area. |
You can disable offset sampling by clicking the Clone Color button in the Color panel or by choosing a non-Cloner brush variant in the Brush Selector panel (Window |
On the property bar, type a percentage in the Opacity box, or move the slider.
On the property bar, type a value in the Stroke Jitter box, or move the slider.
You can also enable offset sampling by clicking the Cloner tool
in the toolbox.
You can set the destination area before painting by clicking while holding down Option + Shift (macOS) or Alt + Shift (Windows). A red marker indicates the destination area.
| 1 | Open both the image that you want to use as a sampling source and the image that you want to use as a destination. |
| If you want to view both images at once, you may want to arrange them side by side. |
| 2 | With the source image selected, click the Cloner tool in the toolbox. |
| If you want to change the brush variant, click the Brush Selector, and click a Cloners brush variant in the Brush library panel. |
| 3 | Hold down Option (macOS) or Alt (Windows), and click the source document to set the sample source area reference point. |
| A green numbered marker appears on the image to indicate the reference point for the source area. |
| 4 | Hold down Option + Shift (macOS) or Alt + Shift (Windows), and click the destination document to set the destination reference point. |
| 5 | In the destination document, apply brushstrokes to the canvas. |
Type a value in the Size box, or move the slider on the property bar.
On the property bar, type a percentage in the Resat box, or move the slider.
On the property bar, type a percentage in the Bleed box, or move the slider.
On the property bar, type a value in the Feature box, or move the slider. The higher the setting, the farther apart the bristle hairs will appear.
Click the Scale Feature With Brush Size button
