Posterizing using color sets
You can use the Posterize Using Color Set option to force your image to use the default color set. Posterize Using Color Set can help make the colors in your image ready for delivery to the web — without a lot of dithering or shifting of colors.
Posterizing means adjusting the number of color levels an image contains. Corel Painter can automatically constrain all colors in your image to a web-safe, 216-color palette. Although the Posterize Using Color Set option is not designed to be a highly sophisticated method of reducing color (it offers you no control over exactly how color reduction is performed), it can be a real time-saver.
In addition, you can constrain the colors you use to the default or another Corel Painter web-safe palette, utilize web-safe single-color brushes, and keep the number of colors in your image to a minimum.
It’s important to note that exporting to GIF format can compromise the color set values used when Posterize Using Color Set has been performed. For best results in those cases, do the following:
To posterize using a color set Back to Top
