If you increase the dimensions of a document that contains a mosaic, you need to re-render the mosaic to ensure the mosaic resolution matches that of the document. This command re-creates the mosaic from the grout color and the tile object information. Re-rendering fills the image with the grout color and then re-renders the mosaic tiles at the resolution of the document. It is important to note that the re-rendering process erases any image that is not a tile or grout.
Choose Effects Esoterica Make Mosaic and Tessellation. |
5
In the Resize dialog box, disable the Constrain File Size check box, and type a higher value in the Width or Height box. |
6
After you click Rebuild, Corel Painter erases any part of the image that is not a tile or grout.
