Corel Painter Help :
Shapes : Resizing, rotating, skewing, and flipping shapes
Corel Painter lets you resize, rotate, flip, or skew an individual shape, or a group of shapes. Before you can work with a shape, you must select it.
Resizing a shape
Rotating a group of shapes
A rectangle (upper left) is skewed by dragging a side middle handle (upper right) and by dragging the top middle handle (bottom).
Choose the Layer Adjuster tool from the toolbox. |
You can maintain the proportions by holding down Shift as you drag.
Hold down Command (macOS) or Ctrl (Windows) and drag a corner handle. |
Hold down Command (macOS) or Ctrl (Windows), and drag a middle handle. |
Choose the Shape Selection tool from the toolbox, and click a shape. |
From the Edit menu, choose one of the following options: |
You can also flip a shape by first selecting it with the Layer Adjuster tool
. Then, to flip horizontally, drag a top or bottom handle past the opposite handle. To flip vertically, drag a side handle past the opposite handle.
