| • | To scale a selection |
| • | To rotate a selection |
| 1 | In the toolbox, click the Transform tool . |
If the Transform tool is not displayed in the toolbox, click and hold the Layer Adjuster tool to open the flyout, then select the Transform tool . |
| 2 | On the property bar, click the Scale button . |
| 3 | Perform a task from the following table. |
Drag a side, top, or bottom handle. On the property bar, click the Commit Transformation button
Drag a corner handle. On the property bar, click the Commit Transformation button
Hold down Shift while you drag a corner handle. On the property bar, click the Commit Transformation button
Hold down Alt + Shift (Windows) or Option + Shift (macOS), and drag a corner handle. On the property bar, click the Commit Transformation button
Hold down Alt (Windows) or Option (macOS), and drag a corner handle. On the property bar, click the Commit Transformation button
Drag a side handle to scale horizontally.
You can also scale a selection by choosing Edit
Transform
Scale, and specifying the horizontal and vertical scale percentages in the dialog box.
If the Transform tool is not displayed in the toolbox, click and hold the Layer Adjuster tool to open the flyout, and then choose the Transform tool . |
| 2 | On the property bar, click the Rotate button . |
| 3 | Move the pointer outside the border of the selection’s bounding box. |
| 4 | Drag a corner handle. |
| If you want to constrain the rotation by 15-degree increments, hold down Shift while dragging. |
| 5 | On the property bar, click the Commit Transformation button . |
You can also Rotate a selection by choosing Edit
Transform
Rotate, and specifying the rotation angle in degrees in the dialog box. A positive number rotates clockwise; a negative number rotates counterclockwise.
