You can change the appearance of channels by modifying their display attributes, which helps to distinguish one channel from another. These attributes do not affect the function of the channel; they affect only how the channel displays in the document window.
Corel Painter names new channels incrementally: Alpha 1, Alpha 2, and so on. Renaming a channel makes it easier to find a specific channel, especially if you have several in the document.
In the Channels panel, choose a channel from the list. |
In the Channel Attributes dialog box, move the Opacity slider to set the channel display strength. |
4
Click the Color chip, and choose a display color in the Color dialog box. |
If you want the channel displayed at its full intensity, move the Opacity slider to 100%. Choose a lower value to display the channel more transparently so you can follow the underlying RGB image as you edit the channel.
