| • | To apply a merge mode |
You can apply a merge mode to a brush variant to control how brushstrokes interact with the underlying colors within the currently selected layer or the canvas. This technique allows you to produce similar results to applying composite method to layers. In addition, it allows you to control where the effect is applied. For more information about composite methods, see Blending layers by using composite methods.
You can set some stroke attributes on the property bar. For more information, see To set brush options on the extended property bar.
| 1 | Choose Window |
| 2 | Enable the Use Stroke Attributes check box. |
| 3 | Move the Stroke Opacity slider. |
| 4 | From the Merge Mode list box, choose one of the following merge modes: |
Uses a combination of the Default method and the Gel method
Works like the Default method; the brushstroke covers the underlying color.
