Using the curve to correct colors
You can use the Curve method to drag the color curves to reshape them. This method lets you create very specific changes in color values.
You can control the overall effect by using the Effect slider. The slider controls how much of the curve moves in response to dragging. When the slider is all the way to the right, the entire curve moves. As the value is reduced, a smaller portion of the curve moves.
The Curve method lets you perform color and tonal corrections by adjusting either individual color channels (R, G, or B) or the master channel (all channels combined).
curve color correction
Curve method of color correction
To quickly adjust colors, you can use the automatic correction controls.
To correct colors using the curve Back to Top
Choose Auto-set from the Curve Preset list box.
Choose White Point from the Curve Preset list box.
Choose Black Point from the Curve Preset list box.
Click Reset.
