You can create a brush library by modifying the contents of an existing brush library and then exporting it. You cannot create a brush library from scratch. To modify an existing brush library for export, you can add new brush categories and variants. You can also exclude brush categories and variants from export by hiding them in the brush library panel. After you’ve exported the modified library, you can import it as a new brush library. In addition, you can delete a brush library from within Corel Painter.
Click Brushes Export Brush Library. |
In the Choose Brush Library dialog box, choose the brush library that you want to export from the Library list box. |
5
In the Export Brush Library dialog box, type a name for the new library in the File Name text box. |
7
Click Brushes Import Brush Library. |
8
In the Import Brush Library dialog box, choose the exported library, and click Open. |
This is the recommended method for creating a new brush library in Corel Painter 12 Update 1 and later. In previous versions of Corel Painter, the only method for creating a new library was by manipulating brush files in the operating system file browser.
Currently, there is no method for creating blank brush libraries.
You cannot delete any of the default Painter brush libraries.
