| • | To define a warp or weft expression |
The warp and weft expressions use the information in the tie-up to extend and evolve the weave into larger, more complex patterns. For more information, see Designing the tie-up.
Warp and weft expressions in traditional weaving
Warp and weft expressions in Corel Painter
In Corel Painter, you need to use the weave pattern expression language to generate a weave. You may find working with the pattern expression language more logical than working with very complex expanded sequences. For more information see, Reference: Expression operators.
| • | In the Edit Weave dialog box, type an expression in the Warp box. |
| As you type a warp or weft sequence, the "Expands to n"message above the panel displays the length n (number of digits) of the expression. This describes the number of threads in the sequence. |
| If Corel Painter cannot resolve the expression, the expansion length message displays "!" (error). |
If you want to copy the Warp expression to the Weft expression, click the Tromp as Writ (pattern) button.
