• | To move a library resource |
• | To rename a library resource |
• | To delete a library resource |
You can move a library resource to a new position within a library, or drag it to a different library. You can also rename resources, such as renaming a paper or gradient, to give them more descriptive names. You can also delete an item from a library, including a default library. You can also restore the default library to the factory settings. For information, see Restoring default libraries.
• | In a library panel, do one of the following: |
• | Drag a resource swatch to another position within the library. |
• | Drag a resource swatch to another library. |
If you’re dragging a swatch to a different library, you cannot position the swatch at the end of the library. You must place the swatch in between, or before, an existing swatch. |
1 | In a library panel, right-click the resource that you want to rename, and choose Rename [Resource]. (e.g. Rename Paper) |
2 | In the Rename dialog box, type the new name in the Rename [Resource] text box. |
1 | In a library panel, click the resource that you want to delete. |
2 | Click the Delete [Resource] button ![]() |
Do not delete default resource files or folders.
