You can import and export brush libraries, categories, and variants. This allows you to work with brush resources that were created by others, or share them with others. You can only import brush libraries, categories, and variants that were previously exported by you or someone else from Corel Painter 12 Update 1 or later.
You can share exported brush resources (brush libraries, categories, and variants) only with users who have Corel Painter 12 Update 1 or later installed. The brush source files of Corel Painter 12 Update 1 or later are not supported in older versions of Corel Painter, including Corel Painter 12 and Service Pack 1.
It is important to note that you can display only one library at a time in the Brush library panel.
Corel Painter 11 (or earlier) brush libraries
You can open brush libraries that were created in an older version of Corel Painter. In Corel Painter 11 and earlier versions, brush variants are individual XML files organized in brush category folders within brush libraries. To use older brush libraries, you must first copy them to Corel\Painter 2017\Brushes. After you copy the files, you can access them through the Brush library panel or the Brushes menu.
Brush libraries that are not in the Brushes folder are not recognized or visible within Corel Painter. The folder structure of brush libraries must match that of the default Painter Brushes library folder (Corel\Painter 2017\Brushes\[library folder]\[category folder]\[variantFile.xml]). If you want to copy only a few brush variants, you must still add them to a brush library while following the correct folder structure.
When you open the older library, you can export it. This converts the brush library to the new brush library format.
Click Brushes Import Brush Library. |
In the Import Brush Library dialog box, browse to the folder where the brush library is stored. |
You can also import a brush library from the Brush library panel by clicking the Brush library options button
, choosing Import, and choosing Brush Library.
You can also import a brush library from the file browser of your operating system by double-clicking a brush library file.
(Mac OS) While pressing Control, click the brush library folder, and click Get Info. In the Info dialog box, disable the Locked check box. Repeat for subfolders and files. |
Click Brushes Export Brush Library. |
In the Choose Brush Library dialog box, choose the brush library that you want to export from the Library list box. |
In the Export Brush Library dialog box, browse to the folder where you want to store the library. |
You can also export a brush library from the Brush library panel by clicking the Brush library options button
, choosing Export, and choosing Brush Library.
Click Brushes Import Category. |
In the Import Brush Category dialog box, browse to the folder where the brush category is stored. |
You can also import a brush category from the Brush library panel by clicking the Brush library options button
, choosing Import, and choosing Category.
You can also import a brush category from the file browser of your operating system by double-clicking a brush category file. The brush category automatically appears in the Brush library panel.
Click Brushes Export Category. |
In the Choose Brush Category dialog box, choose a brush category from the Category list box. |
4
In the Export Brush Category dialog box, click Save. |
You can also export a brush category from the Brush library panel by clicking the Brush library options button
, choosing Export, and choosing Category.
Click Brushes Import Brush. |
In the Import Brush Variant dialog box, browse to the folder where the brush variant is stored. |
4
In the Save Variant dialog box, choose the brush category where you want to store the variant from the Brush Category list box. |
You can also create a new brush category while in the Save Variant dialog box by clicking the Add New Brush Category button
and typing a name in the New Category Name text box.
You can also import a brush variant from the Brush library panel by clicking the Brush library options button
, choosing Import, and choosing Brush.
You can also import a brush variant from the file browser of your operating system by double-clicking a brush variant file. The brush variant automatically appears in the Brush library panel.
Click Brushes Export Brush. |
In the Export Brush dialog box, click Save. |
You can also export a brush variant from the Brush library panel by clicking the Brush library options button
, choosing Export, and choosing Brush.
