Corel Painter Help :
Color : Loading multiple colors
Imagine the ability to load color at a bristle level, picking up different colors with each "hair" of a brush — as though filling tiny ink wells. Imagine also the ability to move multiple colors along with a palette knife, dragging them across your canvas or paper. The Brush Loading feature affects how paint comes off a brush and what happens to the pixels underneath.
When Brush Loading is not active, brushes interact with previously applied colors by sampling underlying pixels and then loading the brush with one new color — the average of those that were sampled. With Brush Loading active, brushes can literally "pick up" existing colors, hair by hair. This capability offers truer color interaction, astounding color variations, and better cloning results.
Choose Window Brush Control Panels General. |
4
Choose Static Bristle from the Dab Type list box. |
5
Choose Multi from the Stroke Type list box. |
6
Choose Window Brush Control Panels Blending. |
7
In the Blending panel, enable the Brush Loading check box. |
The Bleed setting determines how much underlying paint is affected by the brushstroke. A higher Bleed setting, combined with a low Resaturation setting, can enhance the Brush Loading feature. A resaturation value of 0, combined with different levels of bleed, will cause your brush to smear image color, rather than deposit it. In this case, the lower the bleed, the longer the smear. |
9
Choose Window Brush Control Panels Spacing. |
10
In the Spacing panel, adjust the Spacing and Min Spacing sliders to create fewer "echo" artifacts in your smeared stroke. |
It is easier to see the Brush Loading feature if the canvas is not white. To fill the canvas with another color, see Applying a color as a fill.
You can tie brush controls like Bleed to the Controller setting in the Color Expression panel. For example, if you choose Pressure, each stroke bleeds more or less, depending on how hard you press the stylus. For more information, see Expression settings.
