| • | To customize cloning behavior |
You can set various preferences for cloning and for Quick Clone. For example, you can choose to always use the last selected cloner brush variant or enable Tracing Paper.
| 1 | Do one of the following: |
| • | (Mac OS) Choose Corel Painter 2017 menu |
| • | (Windows) Choose Edit |
| 2 | Perform a task from the following table. |
Enable the Close Source Image check box.
Enable the Open Clone Source panel check box.
Enable the Clear Canvas check box.
Enable the Turn On Tracing Paper check box.
Enable the Switch To Cloner Brushes check box.
Enable the Clone Color check box.
To enable the Clone Color check box, you must disable the Switch to Cloner Brushes check box.
Enable the Show Edit Source Image Dialog Box check box.
