| • | To set preferences for drawing shape outlines |
| • | To set preferences for filling shape |
| • | To set preferences for shape tools |
| 1 | Choose a shape tool from the toolbox. |
| 2 | On the property bar, click the Open Shape Attributes Dialog button. |
| 3 | In the Shape Attributes dialog box, perform an action from the following table: |
Enable the Stroke check box.
Disable the Stroke check box.
In the Stroke area, double-click the color chip and choose a color from the Color dialog box.
In the Stroke area, move the Opacity slider.
In the Stroke area, move the Width slider.
Move the Miter Limit slider.
Enable the Fill check box.
Disable the Fill check box.
In the Fill area, double-click the color chip and choose a color from the Color dialog box.
Click the Fill Overlaps
button. |
Click the Don’t Fill Overlaps
button. Multiple overlaps alternate between filled and not filled. |
In the Fill area, move the Opacity slider.
You can also adjust shape flatness by adjusting the Flatness slider.
| 1 | Do one of the following: |
| • | (Mac OS) Choose Corel Painter 2017 menu |
| • | (Windows) Choose Edit |
| 2 | Perform a task from the following table. |
In the Drawing Options area, enable the Big Handles check box. This can make them easier to grab and drag. If you want big points, enable this option.
In the Colors area, click Wing/Bezier Handle, and choose a color.
In the Colors area, click Selected Point/Anchor, and choose a color. The unselected anchor points appear "hollow."
