| • | To switch views |
You can switch between document views and viewing modes to suit your needs. The Default View displays all open documents. The Single Document View displays only the active document, hiding the other open documents. Both views display all standard tools in the workspace. For example, the menu bar, property bar, Brush selector bar, toolbox, and a few additional panels are readily accessible.
You can enable Presentation Mode, which hides your computer’s desktop and taskbar and centers the document window over a solid background. All Corel Painter features work when you use Presentation Mode. On the Mac OS, Presentation Mode lets you display only one document at a time (Single Document View). On Windows, Presentation Mode lets you display one document or multiple documents (Default View).
Single Document View (left); Single Document View in Presentation Mode (right)
You can also change the default document view mode for the application. For more information, see Interface preferences.
| To switch views |
| • | Choose Window, and choose any of the following commands: |
| • | Single Document View — to switch between Default and Single Document View |
| • | Presentation Mode — to enable or disable Presentation Mode |
You can switch views by clicking the Single Document View button
and the Presentation Mode button in the toolbox.
You can also switch between Default View and Single Document View by pressing Command + M (Mac OS) or Ctrl + M (Windows).
On Windows, you can enable and disable Presentation Mode by pressing F11.
